10forty2's avatar
10forty2
Part Name???
I can't for the life of me find a part I need because I don't know the proper name. In the black/grey tank drain/flush basement compartment there is a hole, floor drain, access hole.... that has a plug that unscrews directly beneath the sewer drain and you run the sewer hose through so that you can close the outside basement door while the hose is connected. What's it actually called so I can find one online to order??
  • Thanks everyone! I will have to go to a marine source for the access hatch it appears. PPL has no listings and the one from Camping World is too small. We've got a West Marine store not too far from us, so next trip to the big city I'll check it out. The one on my coach that broke had a handle on it that made screwing it in and unscrewing it easier.
  • On some coaches the hole is too small and you have trouble putting hose fittings thru so I bought the next size bigger in diameter and cut hole a little larger to mount! and no problem !
  • Here are more.
    http://greatlakesskipper.com/boat-doors-hatches-port-windows/access-and-deck-plates
  • That would be a "screw-in deck access and you would normally find it in marine hardware
