billyray50's avatar
billyray50
Passenger side slide window seals
On our return trip back to Dallas. Started hearing a loud annoying wind sound and located it coming from the passenger side slide window on our 2020 Jayco precept 34G. I taped the outside of seals with electrical tape to find it. Wondering if there any way to can fix this without taking it back to dealer which is over an hour away. Going to call Jayco direct to see if they will authorize mobile service. Any other suggestions?
  • Look at the perimeter of the window in the black area to see the delam
  • I have a 2020 34g precept . The window is delaminating from the frame. The noise ( on my last 3. 1 passenger side and now the second drivers side was replaced under warranty. The entire window and frame. A temp fix is a small bead of sealant to stop the noise. It usually fails on the stationary panel vertical frame at the window center
  • AllegroD wrote:
    Did you look to see if you lost any weep hole covers?
    Thanks. I will double check.
