carringb wrote:
Get it to a qualified RV repair center ASAP. Not a dealer.
Your Schwintek system is failing. It's stopping because the motor current is hitting the level that makes it think it's closed. Good chance the under-floor rollers have gouged the floor, but it could be any number of causes for excess drag. In my case, it was because the fasteners in the framing had broke. Eventually, the excess load from this caused one of my pinion shafts to break. Luckily, this happened in my driveway, and I was able to remove one of the motors and move it manually.
If your slide-out finally gets stuck, you may not be able to move it. Lippert deserves a Class Action for the troubles this system has caused. I wouldn't be surprised if this system has a 100% failure rate on large slides.
FWIW - Mine was rebuilt twice under warranty, and then again this last summer out of pocket, to the tune of over $5,000.
To make things worse, MFGs are now required to install the 3-trax system on large slides, but Lippert won't allow retrofits even if the MFG approves it. Lippert told the repair center that they wouldn't warranty any components if I was upgraded to the 3-trax version.
While he had a problem, his hysterics and posts about Schwintek are all wrong.
1. Has anybody tried to operate the Slide in override mode?  If so what happened?
2. You have a full wall slide from the specs for your model. THAT is NOT good for the regular Schwintek system.
3. Contac Winnebago and see what they state about any problems and fixes
4. LCI(Schwintek) just builds the rack system. They have NOTHING to do with who installs it or what it is installed in. Winnebago (any OEM)is responsible for the design and engineering and how the components will work.
5. Yes, the under floor rollers are critical for supporting the room and gliding in and out. This is designed by Winnebago
6. Full wall slides are a problem for the Schwintek system as it is a lot of weight in the room. ALL the Schwintek system does is move the room IN and OUT. Nothing else. It does not support the room.
7. The main thing is to get the room in override and see what happens.
8.Do you know how to reclock and time the motors? It is simple. When you fully extend or retract, HOLD the button for 10 seconds after the room stops. THAT retimes and synchronizes both motors.
9. Is it possible that your 12 volt circuit breaker for that room is tripping when the room stops? Or does the room IMMEDIATELY start to move again when you attempt to move it after it stops after that 3 inches? Doug
