Johno02 wrote:
Our Gulfstream Soach is equipped with a Progressive Dynamics 9100 Series INTELI-POWER converter, providing 80A of DC current. I am adding a ChargeWizard to it to help regulate the charging voltage applied to the batteries. Has anyone else have any experience with this converter and/or the chargeWizard??
PDI 9180 with wizard is Exactly what is charging my batteries (or rather maintaining the charge) just now.
I started researching in 2005, looking to see if there was anything better,, I have yet to find a better converter.. A few I'd rank as good, a few more as good for most RVers, but I have yet to find a better one
The Charge wizard is programmed for flooded wet cells, The proper max charge rate for a pair of GC-2 is 70 amps, but odds are good your system also charges the chassis and of course you have loads inside the trailer so this eats the other 10 amps.
On my coach, with new batteries, I have to add water... annually.
(As they age the frequency increases but new it was Annually).
I highly recommend the Progressive Dynamics Intella Power Wizard controlled units, None better out there.
Does this answer your question?
