ernie1 wrote:
Hey Lynn,
I believe you about the unit being smokeless because you didn't use any charcoal nor lighter gel. I was wondering what your heat source was? The 4 AA batteries must've really have the fan spinning fast enough to create a lot of air turbulence/heat. What's your secret?
Seriously, at $249.95/unit, I'll have to stick to my ole George Foreman grill which I can cook foods just as fast and run it off of my inverter or the generator.
Hi Ernie - the heat source is a hardwood charcoal and the fan super heats it up, which can be controlled with a dial.
I found it to heat fast so it is better to wait a little longer to get the heat more equality distributed. Heats faster in the centre and cooks completely, then move to outside.
L.
