ron_dittmer
Feb 06, 2015Explorer III
As an owner of THIS rear corner bed motor home, I find it entertaining that making up the bed is a serious topic of discussion.
I look at it this way. If I must have the bed all "prettied-up" like my wife likes at home, then I'd want a walk-around bed. But then I will need to rule out a corner bed, twin beds, and cab-over bed, when combined makes up nearly the entire class C/B+ market. What percentage of B+ motor homes with walk-around double/queen beds make up the industry?
Otherwise just flop-fold the extra material against the far wall and be done like I am.
For my wife and I, the real issue with a rear corner double bed is all about access for the person sleeping against the wall. For that person to get out, both should get out, or at least the other person needs to be able to curl up into a tight ball to allow the other to pass.
Admittedly it is not ideal for anyone to have a rear corner double bed. A walk-around would be a lot nicer so each can get in and out of bed independent of each other, and yes you also benefit from a nicely made up bed. But in our case, the rig would get too long to fit inside our garage HERE. So we deal with that inconvenience to make life with a motor home work for us.
38,782 PostsLatest Activity: Aug 11, 2021
