CDNSENIORExplorerJun 05, 2014pine sap removal from rubber roofsWhat do you use to remove pine sap from a rubber roof?
siggyd777ExplorerJun 05, 2014Just use "Rubbing Alcohol",it's also called Isopropyl Alcohol,I used it,It Works.Let it soak in a little!Siggy
Related ContentRubber Roof ReplacementRemoving caulk from rubber roofStaple RemovalRubber Roof helpdicore rubber roof
