John_Joey
Nov 08, 2015Explorer
I had the prior generation of the F53 then yours. The problem was not alignment, but caster. Increasing the caster solved the wandering, but will wear out your tires faster. On the other hand, on most MH's the tires normally rot out before they wear out.
You may want to ask the alignment shop (and do some research) on the appropriate caster for good steering on your generation of the F53.
