Sam_Spade
Nov 08, 2015Explorer
rockhillmanor wrote:
Yup I thought buying the most expensive tires for my MH was a good thing and simply just was not.
"Better" is often a relative thing.
In this case, "upgrading" TWO load ranges might be the root cause of the problem.......ESPECIALLY if the pressure he has come up with is based on the new tire rating.
Going up ONE load range rating might give you a tiny bit more margin but doing that does NOT also mean that you need to up the pressure.
At this point, I think he should go back the pressure he was using with the old tires to see if the problem won't disappear......and then check the tires to see if they aren't still running comfortably warm.
