Thanks for the tip,
Have looked, the plumbing looks straight forward, need one solid enough to stand on, not move around, and fit in the notch provided by the toilet area on the pleaasureway.
What I have is a nice area outside the toilet closet to put the pan, plug it into the floor like the pleasureway to drain, or maybe rig up a pump system to pump from the pan to the gray water tank. I want this to work only occasionally, in cold weather. .
Have not had luck finding the pan and the fitting pleasureway uses to plug the pan in.
Suggestions!?
