cbigham's avatar
cbigham
Explorer III
Oct 06, 2014
pleasure-way shower
Can anyone help me with pictures of the pleasure way shower pan and toilet notch it hooks into?
I saw one a couple of days ago but did not take measurements, I noticed the removable pan plugs into the floor drain also.
I could sure use the measurements if able. I am on a diy project investigation. .
Been interested in either installing a indoor shower in the coachman van I have or trading it out for a pleasureway, possibly roadtrek. I have a 98 Chevy chassis with just 38 k miles on it, I like the layout a lot, van is in great condition,drives real well, just don't like outside shower in cold or snowy weather! I hardly ever use hook ups and try to avoid camp grounds when I can.
I may be able to put the pan system in mine, would appreciate the help.
Thanks,
Chuck
  • Our 2001 PW Excel TD had a shower and you just pulled a shower curtain around the walls, toilet, etc and got with it. The outside shower had more room and you didn't have to worry about getting things wet, but of course you needed to have some kind of curtain or whatever for privacy if you so desired. There was no tub, just take the carpet off the floor so it doesn't get wet. Several years ago there was a posting on the Class B forum about outside shower room using PVC pipe, shower curtain, and hooking up to the side of the unit. You will need to request a search for shower in Class B forum to see how it was made.
