F4Jock
Jul 29, 2018Explorer
MrWizard wrote:
you do realize, the power savings are not the same as if you disconnected the ballasts and rewired the fixtures for straight LEDs
you now have a High voltage LED string with voltage regulator in each tube
and the ballast is still using power to light 'tubes' that are no longer there
its nice that they are Bright
Yup. Power use wasn't the reason I replaced them. Brightness was. I realize that the swap eliminating the ballasts is easy but told ya, I'm lazy. If the ballast goes I'll deal with is then. In the meantime, 1) Take old bulbs out. 2) Put new bulbs in. 3) Have a brew. Worked for me!
38,782 PostsLatest Activity: Sep 10, 2026
