F4Jock
Jul 29, 2018Explorer
wa8yxm wrote:
How much did you pay?
I got some 5 Meter LED strips peel and stick (3m tape) backing from Amazon for less than 10 bucks each.
Took out my short (8 watt) Tubes and removed the ballast. Cut the 5 Meter long into fixture length strips and stuck 'em down Soldered jumpers to all strips work (There is a way to do it without soldering jumpers on but I'm trained in soldering done a lot of it).
WOW is the word I'd use too. Very very happy with results. ONly remaining florcesent is a 120 volt table lamp in the bedroom.
The difference is amazing isn't it? Yeah, I saw all that about strips and I could do that too but I would opt for the non solder method because even though I can do it it's a p i t a. I like the bulbs better because they're so bloody simple to put in. Glad you liked the difference whichever you chose.
38,782 PostsLatest Activity: Sep 10, 2026
