falconman
Apr 10, 2015Explorer
I'm not sure Im understanding the question correctly but plugging the GEN output into the SP input would route the power from the GEN back into the ATS as SP and the relays would click and the hum would return. You could make it a manual switch by disconnecting the wires inside the ATS and replacing the two inputs, GEN and SP with female plugs and the output to the RV (inside the ATS) with a male plug. You might need to extend the wires to make it convenient and use the gutted ATS box as a junction box for the connections.
Going through all that doesn't seem logical to me. Connecting heavy guage wires is difficult to do properly and the required plugs aren't cheap. A replacement ATS is around $150 and would be much easier to install and probably safer.
38,780 PostsLatest Activity: Aug 05, 2026
