tropical36
Apr 12, 2015Explorer II
Slojoe72 wrote:
soooo if I turn off the 2 main power 1 for the house batts, and other for motorhome disconnects, there should be any power at those wires ...... correct.
Don't know why there would be any 12vdc battery power in that area, but just to be sure and safe and especially if you're not well versed in electrical theory and using a voltmeter, shut off and unplug everything and you most certainly want to be unplugged from shore power. You might even want to remove the -neg. ground cables from your batteries, as you never know what might be by-passing your battery switches.
38,780 PostsLatest Activity: Aug 05, 2026
