falconman
Apr 26, 2015Explorer
Slojoe72 wrote:
^^^^. Is that wired the same? Would like an easy install, one that is wired the same.
The actual wiring is pretty straightforward, the length of the wires may be an issue. Because of the size of the wires involved and the limitations on the inside of the ATS enclosure they tend not to leave a lot of extra wire to work with. Different ATS boxes have slightly different wire lug locations. So if you decide to change to a different mfg, study the box layout and/or see if there is any play in the existing wiring if you need it.
38,780 PostsLatest Activity: Aug 05, 2026
