rgatijnet1
Jun 17, 2017Explorer III
On a 30 amp RV outlet on your stick house, you will find that back at your main electrical panel, the neutral and ground are bonded together so even tho they have two separate prongs on the outlet, they are both tied together and electrically are the same.
On the 30 amp dryer outlet, the neutral is bonded to the ground back at the main electrical panel so even tho there is not a separate ground slot, the neutral acts as the ground.
38,782 PostsLatest Activity: Nov 09, 2020
