hohenwald48
Jun 18, 2017Explorer
This thread, as with most electrical threads on RV forums, is fraught with danger and mis-information. If you're able to differentiate between the valid information and the invalid information then you wouldn't need to ask the question in the first place. Call an electrician and do it right. Get somebody who knows about neutral sizing and ground/neutral bonding. At least somebody with a little knowledge and respect for the NEC.
I love the "ground and neutral are bonded at the panel so you can bond them anywhere else you want" comments. And remember, just because something works doesn't mean you should do it. I mean running a separate ground wire and sticking into the ground hole of a different 15A outlet is just down right wrong. :h
38,782 PostsLatest Activity: Nov 09, 2020
