DiskDoctr wrote:
Encore wrote:
I CAN remove the door by swinging it out, but can't reach far enough into the pocket to replace the screws. The dealer JFC had with tools to do this is interesting. Also, I have considered cutting an access hold inside the closet over the hot water heater. That may be the best answer.
Rush
(Whisper) The leftover spot can make a suspended hide, rod packet or string. Attach the pouch to back inside edge of door and ceiling track with long enough string and you can close the hole and access pouch by opening door fully as you suggest to get access.
Sometimes the pad is mounted to the door.
