Bumpyroad
Jan 26, 2014Explorer
cat199 wrote:
I have had no problem with orings, I leave it hooked up to the motorhome. I think the best part is the valve on the end so the hose does'nt leak in the compartment.. I made a plastic cover for the very end of the valve that sticks into the sewer connection at the rv park, it's the cleanest way to handle the hoses I've seen or found. Problem with macerator systems is they drain the tanks to slow, so the solids have more of a chance to just settle in the tank, rather than carried out with the faster drain of the 3" hose.
that is why you should have a black tank sprayer, regardless of what type of hose/macerator/sewer solution, etc. you use.
bumpy
38,778 PostsLatest Activity: Jun 10, 2026
