locster's avatar
locster
Poor water pressure out of shower head
How can I increase the water pressure in my shower head? Whether hooked up to city water supply or via the pump, the output is very weak.
The flow pressure at the other faucets in the coach are fine.
  • Hi,
    Mine had mineral build up at the shower head. It would come out of the tub valve fine, but not the handle. There is a on-off switch on my shower head, I guess it is open all the way. I was able to remove the shower head and clean the little openings on mine. Yet I was still wanting more water. Eventually I replaced the shower head with a 1.4 GPM rated one from Home Depot.
    You might also try pushing a pin into each water spraying outlet, and see if it increases the flow.
    Fred.
