WETSNAIL
Jun 27, 2014Explorer
Portable A/C
Has anyone used a portable A/C unit in their coach when the built in unit has failed? It seems that in an older MH it would be much cheaper than replacing a basement unit.
Cork
Cork
rgatijnet1 wrote:wwest wrote:
Sorry, you simply CANNOT exhaust living space airflow without it being replenished. Mother Nature, you know, HATES a vacuum.
If I were you, I would not get one.
Since I am me, and have several years of experience with my portable heat pump/AC unit, I think I will keep it. Nothing beats actual experience, which is why I got rid of my double hose unit and went with a single hose unit. :B
rgatijnet1 wrote:wwest wrote:rgatijnet1 wrote:
I have a portable AC/heat pump that I use. These portable units come in single hose and double hose.
I chose the single hose unit because I use it primarily in the Winter and I did not want to suck in cold outside air.
So you continuously "exhaust" conditioned, A/C cooled airflow instead bringing in HOT outside air for the condenser cycle.
COOL...
Mine is a 120 volt, 11,000 BTU AC unit and a 9500 BTU heat pump and it works fine and draws a lot less power than the roof top units do. The vents hoses come with adapters to run out the window but you will probably have to also make a filler piece so that you do not get a leak if it is raining. My unit weighs about 65 pounds and is on wheels so you will have to find a location to store it while on the road. Noise wise the portable unit is no louder than my roof top units.
Obviously a more powerful AC unit will weigh more than mine and may need a dedicated power source.
Costco has a portable A/C heat pump for $389.00
Some of these require a condensate removal method.
With the heat pump, if I pulled in outside air, at zero degrees, NO heat pump, roof top or portable, would work, period. Since I am recirculating inside air at 70+ degrees, through my unit, the heat pump continues to heat the air and to operate just fine when other RV's have to use their LP furnace. Since I like to travel in the Winter, in cold temps, this was important.
Now when I use the AC for cooling, I again recirculate the inside air instead of sucking in HOTTER outside air. Exactly the same thing that you do when you put your dash AC on MAX cool.
COOL...
So you continuously "exhaust" conditioned, A/C cooled airflow, instead of bringing in outside (HOT?) airflow that's restricted to/for the condenser cooling path?
COOL...:S
BUMPY wrote:
if air is exhausted from the single hose, it must also enter someplace. that place will be leaks around windows etc. if there is no additional air intake via the second hose. roof acs do bring in fresh air into their air exchange plenum and exhaust to the outside. the inside air circulates past the cold heat exchanger.
bumpy
2oldman wrote:
Where does the water go?
