carp65
Dec 26, 2017Explorer
portable air compressor
Looking for thoughts and considerations for an AIAir 4000P 12V air compressor capability to air 22.5" tires on a Class A motorhome. All information and comments will be appreciated
diplomatdon wrote:Na, I don't think so. If I understand right, the compressor pressure cutoff determines the ride height on the airbags, so probably nothing I should be adjusting.
Mile High, on board compressor should be pumping to 120 to 125# before cutting out. If not governor on top of compressor could be adjusted. 110# should be enough to get you to a tire shop to have it repaired or inflated to proper setting. To me, carrying additional is unnecessary, as stated over 3 million miles majority in BC, and Yukon. Hose and engine compressor all I ever needed, and used very little. Just my opinion for what its worth.
