Looking for thoughts and considerations for an AIAir 4000P 12V air compressor capability to air 22.5" tires on a Class A motorhome. All information and comments will be appreciated
worth.Na, I don't think so. If I understand right, the compressor pressure cutoff determines the ride height on the airbags, so probably nothing I should be adjusting.
Ride height is set with the ride height adjusters, not the pressure output. I also would not attempt to adjust the compressor or governor to obtain more PSI.
I carry a pancake capable of 150 psi but the duty cycle is more around 125-130.
