FIRE_UP
Dec 10, 2020Explorer
JaxDad wrote:
The whole concept of carrying a compressor has me scratching my head.
If your tires are losing air you have a problem, get it fixed.
I check tire pressures as part of my routine periodic circle check, but I can’t remember the last time I needed to add any air, then because I’d picked up a screw.
Not everyone carries a compressor for their COACH TIRES. Having a small portable compressor is valuable in all kinds of situations. Those of us that have Jeeps quite often lower the tire pressure ON PURPOSE to enhance off road capabilities and, depending on how close you are to camp when you're at the end of a trail, you can drive back to the campground on low pressure tires and air them up when you get back.
Or, if you're working on something that needs to blown out or off, you have AIR do to it. Or, if your bicycle or bicycles need air in their tires, you have AIR to do it. So yes, a small air compressor is of GREAT value in all kinds of situations.
Scott
38,782 PostsLatest Activity: Sep 10, 2026
