gmatti's avatar
gmatti
Portable Satellite
We have a 2015 Winnebago Sightseer 33C and recently purchased a Winegard Carryout G2+ portable satellite antenna. We hooked it up directly through the window to establish the receiver and it worked great. Then we hooked it up through the connections in the coach and nothing. I checked and the connectors are hooked up to coaxial cable on both ends. Any ideas what the problem might be? Anyone else having this problem? Thanks, Jerry
  • https://winnebagoind.com/resources/manuals/pdfs/Operator2015/15Sightseer.pdf
    Follow instructions in section 8. Your manual.
    Satellite dish connection is next to the cable connection. (Water service center)
    See page 8 - 7 for receiver hookup.
  • My 2015 Winnebago Vista has a separate sat and cable connection in the utility bay but I was never able to get the sat one to work. The sat connector in the cab overhead compartment apparently was not connected to it. I never found anything referencing an A/B switch although that would make sense. I ended up putting my dish on the roof and per Winne's info, bored a hole and found the sat prewire cable where the info sheet said it should be. When I connected the dish to that, the sat connector in the overhead worked. I found that while I bought my dish to be portable, the extra height of the roof was a wash with the ability to move the dish around on the ground. Since I was climbing up there more often than not, I just mounted it up there. I also had trouble with the HDMI to network converter that Winne uses to get the sat box signal to the TV. The converter said it was for cat 5 cable but the prewire was cat 6. The replacement box from Winne under warranty did not work either (also said cat 5 on it) and researching online found there is much discussion of whether or not the converter must exactly match the cable type. I found a converter on eBay for $35 that called for cat 6 cable. I installed it and it worked fine. I was tired of making trips to the dealer so I just ate the cost and wrote it off to educating myself on converters. Are you sure this is not your problem? Are you getting any pix on your TV from the sat box? If you have your sat box in the overhead to use the HDMI connection there and are getting a blank screen, check the converter and the writing on the network cable to the TV (and 2nd half of the converter system).
  • My 2014 Itasca 30T has the same problem. I have connectors marked Satellite In and Cable In in the outside bay. The wiring diagram shows three different splitters, but no indication of where they may be located. I'm certain one of the splitters is either a cable model instead of a satellite, or is defective. Winnebago apparently believes their products are never to fail and hide all the serviceable connections somewhere behind panels. I'm not willing to tear walls apart looking, so run cables from my portable through windows to each TV.
  • Do you have a roof dish or even prewired for it? If so, you probably have an A/B switch or more than one sat in cable in electronics area.
  • Bill.Satellite I have a separate satellite in connection so not running through the cable connection. It's obviously a problem with the internal coaxial cable but just checking to see if anyone has had this problem and what the solutions was. Probably need to run a new coaxial cable from the outside connection to the interior connector.
  • I added a separate coax running from our electrical bin to the satellite receiver. That lets us have both satellite and cable hooked up if we want to.
  • I use my factory cable wiring but there are no amps or switches in the path.
  • Assuming you mean you hooked it up through the coach "cable" connection, that won't work. You either need to run a new direct line or, depending upon your coach setup, you may be able to modify the Cable connection to allow either cable or satellite.
  • Can not go through the amp .. must be direct..I've tried the same, no luck at all. I run portable satellite cables through the slide out seals.
