drifterpilot
Jun 18, 2014Explorer
Potential AC Converter Problem
I am away from home traveling near Farmington, NH.
My house batteries are not charging either by generator or shore power.
I am plugged into 50A shore power and power is available in the coach as displayed by my microwave display "blinking".
My refrig will only run on propane.
Four AC outlets work, two don't work.
I looked at the converter and the two 30A fuses were blown.
With the converter AC power cord unplugged, I tried twice to replace the 30A fuses. No luck, the fuses blow as soon as I try to insert them.
My converter info: PARALLAX Power Components 45 Amp
Series 7400, Model #7445
Input: 105 - 130 V
Output: 13.8 VDC
I have followed the black power lead back to the 12V power panel and see nothing obvious. The two green cables going into the converter have tight connections.
Do I have a malfunctioning converter?
Input: 105 - 130 V
Output: 13.8 VDC
