dennislanier
Jul 27, 2015Explorer
Power awning questions
I have a 2004 Jayco Granite Ridge with a Carefree One-touch power awning. It has started to intermittently stall when I take it in or out. I have done a search but have not found specific answers to my question, which is how to do a logical troubleshooting procedure for this unit. For instance, what locations to check the voltage readings and what the most likely cause for intermittent operation would be. Sometimes it works fine, other times it rolls out part way then stops, I let it sit for a while, and then it works again. I am assuming the motor is ok or it would not work at all, maybe a bad connection somewhere? Anyway, any information on a logical process to check it out would be appreciated.
