Walt3
Jan 28, 2014Explorer
Power chips
I keep seeing advertisements for power chips in RV materials. I was wondering if anyone had installed one of these chips and their results? I have a Workhorse chassis and a 8.1 liter engine.
et2 wrote:
Feel free to contact Ford or GM and see if they will void the warranty if their ECM is adjusted and still remains within the design specs. That is what Brazel's did and they use the manufacturer's own criteria with their ECM. It will not affect your warranty. They are not to be confused with someone adjusting an ECM for racing performance.
In truth, adjusting the ECM for the actual vehicle weight and use may actually prolong the life of the engine as well as producing fewer emissions.
If you've got the documentation Ford and GM will just let you play around with their ECM then please post it. Otherwise I say your spreading false information. Telling people to go try it for themselves and see is way out of line.
