dougrainer
Jan 16, 2019Nomad
T18skyguy wrote:
Thanks Doug your right, it's an Equalizer system on my 2017. I thought it was made by Power Gear? Guess I'm wrong about that. It always alarms if it sits a long period of days on my off level pad. So I wasn't sure if perhaps a jack was bleeding down, but your explanation really helps. Is that pressure switch inside the oil reservoir or on the jacks ? I figure it will need attention some day.
The pressure switch is on the pump manifold block and Equalizer states that if it takes more than 48 hours for the pressure switch to lose partial pressure and cause a Auto retract, that is normal. This is not a cause for concern. Doug
38,773 PostsLatest Activity: Apr 25, 2026
