Sort By
- NO RV motorhome Hyd Jack/leveling system uses another/shared Hyd canister. The Powergear has its OWN pump/reservoir. The normal cause of alarm when retracted is LOW fluid in the reservoir. Powergear Jack systems use the level to indicate all jacks are retracted. The fluid is Dextron 3 Trans fluid. Doug
38,718 PostsLatest Activity: May 03, 2025
