Bigsteve909's avatar
Bigsteve909
Power gear levelers
Hey everyone, I have a 2007 fleetwood excursion 40e my levelers are up and I can’t get the jacks down light to turn or stop making noise. I’ve done all the troubleshooting suggested and still not working. I’m wondering if anyone on here has experienced same thing. Thank you in advance.
I can manually jump from outside control panel but no response as from inside house panel.
  • If theses are Power Gear hydraulic, they use the hydraulic level in the reservoir to detect if the jacks are retracted. If the level is a little low, it thinks the jacks are still down.
    With the jacks fully retracted, top off the reservoir with fluid. This is how I did it on mine.
    https://www.1999southwind.com/flush-and-refill-leveler-hydraulic-system/
  • Electric jacks right? Power Gear has a lot of trouble shooting guides on their site that might help. Your problem is one that I haven't had....yet. Good luck.
  • Find your Jack reservoir and check to see if the fluid level is low. Low fluid level can give you the kind of problem you are posting.
    Happy travels. Arnold
