gsf35099
Mar 23, 2015Explorer
UsualSuspect wrote:
I had the same issue, same pad. Locate the circuit board that the jacks and sensors plugs into, mine was mounted upside down. Over time the connectors had vibrated loose. I just unplugged, and plug them back in one at a time and it took care of the problem. I am thinking about using wire ties if it does it again.
Thanks, I got under there and found my controller bolts holding it in place loose and wiggled the plugs, but didn't unplug them & put back. I'll give that a try before I buy a new touch pad. I think I will also ohm the harness to make sure between the touch pad & control panel.
38,769 PostsLatest Activity: Mar 29, 2026
