dougrainer
Nov 29, 2015Nomad
You need to check the Coach battery water. Odds are the batteries have NO water and are dead. The reason you have power on 50 amp and Genset is the Converter is supplying the 12 volt power. With the Chassis engine running the Chassis engine Alternator is then supplying the 12 volt power. Doug
