dougrainer
Nov 29, 2015Nomad
revrick3 wrote:
Thanks, batteries are only 1 year old, both of them, System was working fine then it just stopped while driving. When I disconnected from shore power the lights worked and steps worked. Then about an hour later nothing worked. The inverter circuit breaker, where is this at. Can you walk me through how to trace this down. Remember guys, I am fairly familiar with 12 volt auto and 110 house current but this is a mix with inverters an converters and this is all new to me.
"Thanks, batteries are only 1 year old, both of them"
Batteries need constant vigil to make sure they are not boiled dry. Check the battery water. If left plugged in that will give a constant charge to the Coach Batteries and will boil them dry. Your Inverter/Converter circuit IS working or you would NOT have 12 volt power from Shore Or Genset. Doug
38,781 PostsLatest Activity: Aug 12, 2026
