Bill_Satellite
Mar 02, 2018Explorer II
Did you remember to turn off EVERYTHING 120V in the coach? If you are plugged into a standard 15 amp home outlet you could easily drop the voltage below acceptable units even before the home breaker trips. You should have 2 red lights lit plus the 1 red light blinking if the wiring is correct between the house and RV. After 126 seconds the blinking light should go out, the other 2 lights remain solid and you should hear the "klunk" and you would have power.
Which part of this scenario is missing?
