rgnprof
Jun 18, 2018Explorer
Power steering pressure hose leaking at steering box
My '93 E350 power steering pressure hose is leaking at the threads where it screws in to the steering box. I replaced this hose just last year and it's pretty much leaked ever since...O'Reilly's will replace it (under warranty), so I got a new hose yesterday.
It only came with 1 o-ring - same as the first time I bought the hose. And it clearly looks like that o-ring goes on the connection to the pump, not the box.
Question - how does this thing seal at the box? This is the hose I bought...
Pressure power steering hose
If it's leaking at that connection. It needs to be pretty tight, using a Tubing Wrench.
If you're tightening with an Open End Wrench and stopping because it's starting to round the flare nut off, you may not be tightening it enough. I'm sure there's a torque spec.
