John_Wayne
Aug 31, 2016Explorer II
You need to pull the unit and see if the gears on the motor are stripped, if they are you can buy a new motor at the parts store (they are usually power window motors). If the gears in the gear box are stripped you will need new gears for that or a new gear box. Make sure you pull the plug for the step motor before working on it if it started working while your arm is in-between something it can do damage.
38,766 PostsLatest Activity: Jan 10, 2026
