FIRE_UP
Aug 31, 2016Explorer
hikerman wrote:
I can hear the electric motor running for the power step, but they will not stay all the way up nor will they extend and stay all the way down. They had worked just fine for 900 miles last week, but after 48hrs in storage they started this 'missfire'.
Any experience with something like this?
Well Sir,
It all depends on just which Kwikee system you have. Apparently there are different gear setups in their lineup. About a year ago or more, ours displayed some of the same symptoms only, it would go out and "ratchet" at the end of the stroke. So, I tore into the gear box and found the driven gear, the 3" one, to have two broken teeth but, the drive gear, the little one on the motor was just fine.
Well, Kwikee being Kwikee, doesn't just sell gears, they wanted me to "upgrade" to a whole new mechanism for oh, about $300 or so. Well, that ain't happening. So, I cruised around on Amazon and low and behold, I found the exact gear box that was/is the same as ours. I got that thing for a whopping $60.00, yahooooo.
Anyway, if I can display the pics correctly, I'll show you what ours looked like. Yours may, or may not, be the same system and, have the same problems. You'll have to decide.
Scott
38,766 PostsLatest Activity: Jan 10, 2026
