EUREKA12's avatar
EUREKA12
Pre inspection mechanic/Tucson
We are making a deal on a 2007 Holiday Rambler Imperial 42FST. Can anyone give me a recommendation for an "inspect and advise" person/company in Tucson, AZ. Expensive rig here and do not want to purchase anyone else's problems without knowing what we are facing. This floorplan has a "whole" house slide on the driver's side. Considering this is a 42' coach, I would be interested in knowing if this is potentially an issue I should concern myself with as well.
Thanks for any assistance anyone might offer.
Eureka12
  • Thanks everyone. Premier RV is who we are purchasing the coach from. They say when they are through with the inspection no one is more thorough or better. Sounds as if they are right.
    Thanks for your help.
  • Premier RV is just around the corner from Lazydays. They sell and service high end MH's. They will do a thorough prepurchase inspection. Well qualified to work on this coach. Expensive but worth it!
    Moisheh
  • You might want to check with "All RV" on Grant. I have used them for repairs in the past with good result and a pre purchase inspection might be something they could do for you. :C
  • I would recommend Ken Cameron of Cameron Reliable Mobile RV Service. I don't know if he does inspections but as far as I can tell, he can fix any problem on any motorhome. Give him a call at 520.490.7632. Also sending you a PM.
    jor
    Forget the PM. Message says you don't allow them.
