Hikerdogs
Feb 01, 2015Explorer
If it's built on a Ford chassis it is at least partially wired for brakes. Ford installs the plug under the dash for the controller, and runs all the wires to the end of the original frame rails.
The body builder may have added frame extensions. If they did and didn't run all the wires to the rear of the coach they should be folded back and taped in the main wiring harness on the drivers side frame rail at the junction of the Ford supplied frame rail and the extensions.
All the wires in the harness should be labeled as to what they're for. The easiest way to find them is follow the ones that are at the rear of the coach forward until you reach the large loom at the end of the original frame rails. Then open the loom and look for the additional wires. The last 6 inches or so are usually folded forward and taped to the other wires in the loom.
The easiest one to find is the light blue #10 wire labeled "brakes".
One other note, The plug for the controller under the dash usually requires a short jumper harness to match the plug to a specific brand controller. We used a Tekonsha Prodigy controller (now replaced by the Prodigy P2). You can also buy the jumper harness from Tekonsha. They are chassis specific i.e. Ford, Workhorse (Chevrolet), Dodge, etc.
38,763 PostsLatest Activity: Dec 05, 2025
