goufgators wrote:
I haven't used the furnace in a couple of years. Turned it on this morning and only the fan worked. The propane burner failed to ignite. I tried it several different times with no luck. I checked the cook stove and all burners worked fine. Any thoughts re: how to get the furnace burner to work? Thanks, Larry.
Thanks to all for suggestions. Because it's gas operated (propane), and I'm not real comfortable following through on some of the suggested 'fixes', believe I'll take it to CW and let a qualified mechanic find and repair the problem. Yes, I know "CW" and "qualified mechanic" is considered by some to be an oxymoron (sp?) :) but I've had reasonably good service over the years from the one near Tallahassee. Again, thanks! / Larry
