Dutch_12078 wrote:
Is there a mud flap behind the front wheel? If not, add one to cut down on the water spray. The propane compartment must be well ventilated in case of any leakage, so sealing up your other compartments as they should be would be your next step. A layer of window screening could be used I suppose, to close in the bottom of the propane compartment though. That would at least deflect some of the water and break up the rest into more of a mist without compromising the ventilation.
Get a mud flap that has what looks like fake grass on the front side. It will catch the water spray & drop it straight down. Helps improve visibility in your mirror as well.
