DrewE
Oct 28, 2016Explorer III
Disclaimer: I have no specific experience with doing what is proposed.
The most likely possible difficulty I can come up with would be excessive condensation inside the shed. The furnace is putting a good bit of moisture in the air in the shed (along with carbon dioxide), and metal buildings, particularly uninsulated ones, tend to be prone to condensation since the skin is a pretty decent thermal conductor.
Having adequate air exchange in the shed to keep the condensation at bay would, I suspect, also be more than adequate to keep the oxygen levels appropriate and, assuming the furnace is operating properly, the carbon monoxide levels at a safe point. If the furnace is misadjusted it could emit a good bit of carbon monoxide that would otherwise be dispersed more or less harmlessly in the outside air.
38,780 PostsLatest Activity: Nov 24, 2017
