Dutchman_31
Mar 29, 2018Explorer
Propane Issues in Cold weather
Having problems with our heater when temperature is below 30 degrees F. We noted little or no gas flow on our water heater and stove as well at the same time. When the coach and ambient temperature warms up the problem goes away. We had the propane tank filled and everything operated properly. When we woke up the next day the same thing occurred again. Thinking there may be moisture in the propane tank? Anyone experiencing a similar issue? Regulator?
