msturtz
Aug 21, 2019Explorer
DallasSteve wrote:
way2roll
I did a comparable search on RV Trader. I looked at new Forest River products to keep them comparable. I looked at about 35 feet long. I'm looking at gas, not diesel on both a motorhome and a tow vehicle. I see Class A motorhomes starting about $90,000. I see new 5th wheels starting about $35,000. As Don Henley says "Are you with me so far?"
I looked at new gas Ford F350 DRW. That should be plenty of truck. NADA says they run about $40,000. True or false? I don't know. I suppose you can spend $75,000 on a King Ranch F350, but all of this is targeting economical and comparable. I'll figure a new economical toad, not a Jeep; say about $25,000. Here's how my numbers look.
$90,000 Class A
$25,000 Toad
$115,000 Total
$35,000 Fifth wheel
$40,000 Ford F350
$75,000 Total
I doubt there is $40,000 of "fudge" in my quick and dirty numbers.
Steve
The problem is that the listed 5th wheel towable unit is in no way equipped similarly to a Class A. There is a reason for the apparent price difference. For example the motorhomes come with an onboard generator and usually have a large battery bank and inverter. No one is disputing that an inexpensive 5th wheel plus the equivalent of a work truck can be purchased that costs much less than a motorhome however you are not comparing the same things either. Option for option feature for feature. Does the motorhome have an automatic leveling system? Then so should the 5th wheel trailer. I can tell you from personal experience that riding in a work truck and riding in any motorhome is not equivalent either. Nor is the fuel range equivalent either without aftermarket additional tanks which I added to my setup. The F350 gas may only have a 40 gallon fuel tank at most the motorhome has a 80 gallon fuel tank. I know about these limitations because I lived it. I used to have to carry many gas cans with me till I installed the auxiliary fuel tank. Again in any comparison it is important to consider all the facts. Since I have built a great towable setup before we got our motorhome I am acutely aware of the difference in features between both platforms. Bottom line is that it depends on the individual requirements of the person using the equipment. I have a CDL and work for a heavy truck manufacturer I look at an RV like any other tool. I try to determine what our requirements are first and then look for most logical solution that fits within the budget.
I did a cursory check for 5th wheels on RV trader equipped with generators and residential refrigerators and the discounted prices start at about $90k. I am assuming that they have automatic leveling systems.
38,780 PostsLatest Activity: Aug 05, 2026
