tomman58
Aug 26, 2019Explorer
msturtz wrote:tomman58 wrote:
Almost everything I read here I can do with my 40" TT. I have had to hook up in the rain (20 minutes tops)but most of the time if we are leaving in the morning I pull in the slides except the bedroom and unhook the sewer and water AND TV THE NIGHT BEFORE( ALL OF WHICH YOU HAVE TO DISCONNECT IN A MH.) Our water and toilet work of course when we are between sites.
Our trailer has auto level so I just push a button and when we reconnect it raises the gear and puts the tongue at the hook up level.
We have almost zero costs and the tires which we replace after 60,000 miles are about 500 bucks in a Class A they can run 2400 bucks and the other maintenance is also expense and not readily available in several areas and God help you if you need something major as it can be weeks for the repair.
The only other thing I can think of as a deterrent is the space my TT slides open further and I have more usable space.
Lastly is cost my TT costs 48000 how much is a MH? 180 to 500 thousand that is a large investment almost as bad as owing a sailboat!!.
Your TT seems very nice. To be safe I had a $3000 Hensley hitch which adds cost. Your point about tires being less expensive is correct however I went through about 6 tires in 10 years in my towable unit because the ST tires are not made to the same standards that Motorhome tires are. With my motorhome if the weather is going to be poor I routinely disconnect everything but power since it has 110 gallons of fresh water and a 50 gallons black and grey capacity. With automatic generator start I don't worry about requiring power. We spent over 3 days dry camping in 100F heat in a farmer's field with the ACs running. I could not have done that period with a TT. I would have had to refill both water and gasoline for the generator at least once. We had a situation with our motorhome when the power went out and the AGS system kicked the generator on automatically and the rig was nice and cool and the batteries were not dead. I know of very few towable units that have this technology. It isn't that it isn't possible. My point is that if the fewer features available in the towable market work for a person then great it can be much less expensive, however if you want or desire the more advanced features available in the motorized market then that can be a good value as well because by the time you add all the features you get with a motorized unit to a towable unit you are in the same price range with the same features. Bottom line feature for feature, item for item if you have equivalent features both platforms cost a similar amount. Now if a person already has a suitable truck then the equation changes quite a bit. Each person's situation is different. For us, we couldn't handle a towable due to our kids being born prematurely. In addition, I have some health issues that make handling the extra work of a towable harder to do. We have found that we make many more trips than we ever did with a towable because it is so much easier. Even with a toad I can be hooked up and ready to go in a few minutes where with a trailer this isn't even close, it takes a long time to get hooked up and ready to leave.
Never needed a Hensley. My hitch has been on 6 TT. your excuses for having a Class A are noted but not the rule. A Class A is not even close in cost. 250,000 compared to 48000 for a TT is not even close. As for my truck it has uses other than camping and is needed for my runs up the slab to our northern house. If you want to time a hook up with me you had better practice often, we put on 1000's of miles a year as I can normally be on the road is 20 minutes in an rain storm.
Tires are far better now and as for weather that is what GPS was invented for .... to miss the big issues on the road.
