polar76's avatar
polar76
PRXB problem...
My 1997 CC Allure has a PRXB Pacbrake, exhaust brake which replace the original sometime around 2005.
The coach now has 67000 miles on it of which I have put about the last 36,000 on it.
The engine is an 8.3L Cummins (mechanical) with an Allison 3060 tranny.
The problem: I am getting almost no breaking from the PRXB.
It operates fine every time the key is turned on it cycles once and I have observed this.
The cylinder extends fully and the butterfly valve appears to close. (viewing from the outside of course).
I ran a test to see if it was getting a good signal when driving , by running a wire from the switch on the throttle linkage all the way to the drivers seat and took a test drive.
When the switch was engaged my meter would show 12 + volts. and I can hear a slight change in the engine noise but hardly any breaking if at all. Tried this from 5th all the way down to 2nd gear… essentially the same results.
Any suggestions before I pull the brake of to inspect it further???
  • Does the transmission downshift toward the pre-select gear?
    Have you checked for exhaust leaks-- if a leak before the exhaust brake, it will NOT build back pressure? Look CAREFULLY for black exhaust trails: between head and exhaust manifold, exhaust manifold itself, exhaust manifold to turbo, turbo to exhaust brake.
    If all the above is OK, there is a test port on the PacBrake where you can connect a pressure gauge to see what back pressure it is providing.
  • It is possible for them to wear out to the point they leak so much that they dont do much but that is very rare.
    I would be more inclined to make sure the torque converter is still locking up.
