Gator48
May 19, 2013Explorer
Something I didn't see mentioned here is how the TV is set up to select channels. Most TVs have a setup menu where the user can select either normal OTA channels or cable and then do an automatic channel scan.
Look on your remote for the menu button then look for setup or channels or channel setup. You will need to select "cable" in order to get the Comcast channels over the cable connection.
Also, the cable may indeed go through a selector switch box and if this is the case you will need to change the button to the cable the position BEFORE you run the cable setup on the TV.
Let us know if it works
38,782 PostsLatest Activity: Sep 10, 2026
