pnichols
Jun 14, 2018Explorer II
Our 24 foot Class C is on an overkill E450 chassis with frequency-sensitive-damping shocks in the rear, so it doesn't rock or sway when we walk around in it. Stabilization jacks are not required and would only be just one more thing to mess with when making/breaking camp.
We have camped/parked in many off-highway places and in many campgrounds over the years and I can count on one hand the spots that were level enough so as to not require extra work when setting up. Also, we like to keep our Class C's ground clearance at a maximum and things to mess with (or trust to always work) at a minimum. We even have oversize tires on our RV for better ground clearance. We never know where we might wind up wanting to camp, so must be ready for anything.
I made five (5) 3-step leveling blocks out of 2X8 treated lumber, plus we carry additional pieces of treated 2X8 lumber. This makes us ready for the maximum three-point leveling situation of raising of the two rear dual tire sets and one front tire - all by different amounts if necessary using the step blocks and lumber pieces. IMHO ... this is a simple, cheap, and light weight method that will never break. (We also carry a shovel for the worst case scenario of having to dig holes for some of the tires!)
Shortly after buying our RV, I placed a bubble circle level on the floor next to the refrigerator and drove around until the bubble was centered in the circle. While parked there, I then glued a small graduated linear bubble level on the dash in front of the steering wheel and another small graduated linear bubble level on the driver's side door close to the steering wheel - of course carefully glueing them such that both bubbles were exacting centered in these small levels. Ever since doing that, I can now get the floor of the RV level merely by driving back and forth enough to get the bubbles centered in these two small graduated linear levels that I mounted in the cab on the driver's side.
However, we often do not "level" the RV level on purpose. We sometimes want the rear bed such that the head is slightly higher than the foot. When parking in a camping spot, I just jocky back and forth until the level on the driver's side door shows as "one bubble or one-half bubble high" in the rear. Doing leveling adjustments like this couldn't be easier or more reliable!
38,782 PostsLatest Activity: Sep 10, 2026
